Yet another camaro you do not want to mess with either!
YET ANOTHER CAMARO YOU DO NOT WANT TO MESS WITH EITHER!
I have been very fortunate with the Pedderized Camaros for sure. This one is set up to feed on victims! It will be seen in the SF Peninsula, to San Rafael, to Infineon Raceway, and yes at Infineon Raceway. The SF Bay area is becoming a Pedders stronghold for killer Camaros.
She has been corner balanced, and aggressive alignment, and a lot of meat on the ground and major engine mods are on their way! The setup is between me and the owner. Check her out and be aware!
Front Pedders Xa strut assembly installed
Pedders front steering gear bushing installed
Pedders front radius rod bushing and Caster eccentric adjuster
Removing the OE Differential Bushings using the Pedders tool
Rear Differential with our Pedders EP1167HD bushings for serious hp and torque!
Removing the front OE subframe bushing using Pedders tool. takes 2-3 minutes a bushing. EP1201HD, our most serious rear subframe bushings are installed!
The front subframe bushing removed with the Pedders Tool
mike
dms
Killer Camaro to Avoide Part II
Removing the large rear subframe bushing using our Pedders Tool. Takes 2-3 minutes per bushing
Rear subframe bushing removed using the Pedders Tool
Front EP1201HD bushing installed. This is a very serious bushing for very HD driving and torque
Rear inner toe link bushing with Pedders HD rear eccentric bushing
Left rear suspension showing Pedders Xa Coil over, sway bar, adjustable HD end link, rear EP1201HD bushing
Rear suspension showing Pedders inner toe link bushing and custom HD eccentric, inner trailing arm bushing, and front EP1201HD subframe bushing.
Rear suspension showing the Pedders outer trailing arm and toe link bushings at the knuckle
I hope you enjoy these pictures. I tried featuring different aspects of a Pedders Track II kit with each. If you have any questions, just ask.
thanks
Gtpguy
Jan 26, 2015 04:50 PM
