What other V6s are in the same engine family?
Current domestic GM V6 engine displacement ranges from the Saab/Holden 2.8L Turbo up to the old 4.3L Small Block. Obviously the 4.3L is the only V6 in that family, but is the 2.8L related to anything else we have? Aren't the 3.5L and 3.9L in the same family? The Buick 3.8L is obvious. Are the 3.6L engines related to any other engines?
"High Value" OHV V-6: 2.8L, 3.1L, 3.4L, 3.5L, 3.9L, all 60 degree bank with firing order 1-2-3-4-5-6
"High Feature" DOHC V-6: 2.8L, 2.8L DI turbo, 3.0L DI, 3.6L, 3.6L DI, all 60 dergree bank with firing order 1-2-3-4-5-6
3.8L Buick V-6
4.3L V-6, 350 with 2 cylinders chopped off
3.4L DOHC V-6 (1990s) "High Value" V-6 family with DOHC heads
3.5L Oldsmobile V-6 "Shortstar", Northstar with 2 cylinders chopped off
The 4.6L Northstar was roughly based on morphing the 3.4L DOHC V-6 into a V-8
I think this covers most of them.
3.8L Buick V-6
3.8L Buick V-6
3.8L Buick V-6
I'm surprised that the LP9 isn't more powerful. It should be making closer to, or over, 350hp instead of only 280. Maybe it uses less boost than the LNF? If the LP9 made the same specific output as the LNF or at least close, then it would be a great engine for the Camaro.
Hoodshaker
Aug 27, 2002 02:32 PM
