Rule The Streets! Magna Charger ZLs Supercharger System for 2010 Camaro!
Old Jun 22, 2009 | 04:17 PM
JasonD's Avatar
Admin Emeritus
Arrow Rule The Streets! Magna Charger ZLs Supercharger System for 2010 Camaro!
Interested in getting a discount on a Magnacharger kit for your 2010 Camaro? Head over to HotPart.Com, and add the kit to your cart. Use coupon code 500camaroz28 750camaroz28 during checkout and get $500 off $750 off plus free shipping!!!
VENTURA, CA – Like the iconic ’69 ZL1 Camaro, the new Magna Charger ZLs™ equipped 2010 Camaro features an all-aluminum 500hp engine wrapped in crisp Gen 1-inspired sheet metal. However, that’s where the similarities end. Chevrolet sold just 69 of the highly coveted ZL1s and virtually none of them ever saw the street. By contrast, almost anyone can build a Magna Charger ZLs. It’s as easy as bolting on a new Magna Charger MP 2300 TVS supercharger system. While the original ZL1 was reported to have more than 500hp and 450ft.lbs. of torque pushing the car to low 13s @ 110mph, the ZLs is even more powerful, and capable of 12.5s @ 115 mph. What’s really nice is that you can drive the Magna Charger ZLs every day without a penalty in fuel mileage or low-speed driveability. Where the original ZL1 was a cantankerous 8mpg anachronism, the ZLs is smooth, quiet and clean – equally ready to deliver top EPA mileage figures or smoke the tires in any gear – your choice!
This information not for repost. Please link to tr.im/2010camaromagnacharger instead.
Magna Charger’s new MP 2300 supercharger technology is the same used for the new ZR1 Corvette. The four-lobe rotor features a high-twist 160º helix that has improved efficiency (less power to drive), cooler discharge temperatures and is much quieter. Additional efficiency is the result of the unique bypass valve that reduces parasitic drag during normal driving. The Magna Charger also interfaces seamlessly with the GM Active Fuel Management system (some models) that cuts the engine to four cylinders at light throttle.
The Magna Charger ZLs system comes complete with a new, patented high-velocity aluminum intake manifold, integral water-to-air intercooler, and all necessary brackets, connectors, hardware and any needed specialized tools. The supercharger has a self-contained lubrication system that is maintenance-free. Calibration is included with a handheld computer programmer that re-programs the factory ECU and stores the original calibration for possible future use. A full instruction manual with color photos makes the step-by-step installation process easy to follow.
All Magna Charger supercharger systems carry a Standard 3-Year Limited warranty on the supercharger system, and Magna Charger also offers an optional 36,000-mile/3 Year Powertrain Warranty. For more information and to order, please visit http://www.hotpart.com
UPDATE!
Attached is a very cool large image of the 2010 Camaro with the magnacharger installed! Great for desktop wallpaper!
Attached Thumbnails Rule The Streets! Magna Charger ZLs Supercharger System for 2010 Camaro!-magwllppr.jpg
Old Jun 22, 2009 | 04:36 PM
JakeRobb's Avatar
Super Moderator
Cool.
12.5 @ 115? Seems like half a second and 5mph isn't much to gain from a supercharger. Then again, this is powertrain only, right? No suspension or tire changes? With that in mind, wouldn't it be more informative to talk about dyno numbers than quarter mile times?
Old Jun 22, 2009 | 06:49 PM
426HPSS's Avatar
Thumbs down
is factory 5yr /160Kms and or GMPP lost when these babies are installed??
I assume yes...
Old Jun 23, 2009 | 12:08 AM
YoungCompton's Avatar
VERY NIYCE!!!!(Borat voice)
Old Jun 23, 2009 | 07:06 AM
2010_5thgen's Avatar
whats the difference between the mp 2300 and the tvs2300 that lingenfelter and hennessey use?
what is all included in the kit? the programmer,blower, fuel injectors? intake?
Old Jun 23, 2009 | 09:56 AM
hotpart's Avatar
Former Vendor
Originally Posted by JakeRobb
Cool.
492 RWHP and 455 ft.lbs. RWTQ! These are the ratings Magnuson will be publishing, and they are produced with only 6 pounds of boost.
Old Jun 23, 2009 | 10:21 AM
mdenz3's Avatar
No dyno numbers?
Old Jun 23, 2009 | 10:23 AM
JasonD's Avatar
Admin Emeritus
https://www.camaroz28.com/forums/sho...d.php?t=695009
Old Jun 23, 2009 | 10:48 AM
Andy30thZ's Avatar
If it's anything like the vette's, it'll rip!!
I'm assuming that 6psi is about the safe limit without meth injection?
Will someone figure out if this rear end will withstand any kind of abuse? Hate see all the money spent only to run on slippery street tires.
I'm hearing axle shaft spline failures on the street with street tires? Hopefully just a manufacturing defect.....
Old Jun 23, 2009 | 12:09 PM
what is all included in the kit? the programmer,blower, fuel injectors? intake? is anyone here a distributor of magna charger?
Old Jun 23, 2009 | 01:01 PM
hotpart's Avatar
Former Vendor
Magnuson is not allowed to use the trademarked TVS name but they are the exact same units. Hennessey and Lingenfelter both utilize the Magnuson Products supercharger system that includes all of necessary components required for a complete and thorough installation. The programmer, fuel injectors, intercooler, intercooler pump, intercooler reservoir, hoses, clamps, wiring, fuses, intake manifold gaskets, intake manifold, intercooler, aftercooler, brackets, hardware, manifold lid, supercharger, inlet adapter, hump hoses, auxiliary shaft, auxiliary belt, auxiliary bearings and every other nut bolt washer wire tie and fuel disconnect tool that you will need to properly install the supercharger kit.
For now the computers must be sent to them for programming until the handhelds can be upgraded to the new applications.
Old Jun 23, 2009 | 02:11 PM
how long/short an easy/hard of an install is this for , lets say , a guy who isnt very mechanically inclined...... its my friend..... not me.... he's shy. thats why im asking.
Old Jun 23, 2009 | 02:14 PM
will the factory engine cover fit over the blower? i think that would be slick if you could hide it under there.
Old Jun 24, 2009 | 12:01 AM
BOSSUPSGENERAL's Avatar
Do you think these will be legal in california?
Old Jun 24, 2009 | 01:21 PM
TS 95Z's Avatar
I don't know about hiding it completely, but the sides have been put back on with some modification:
