View Poll Results: What engine would you rather see?
7.0---427!
148
52.11%
6.2 S/C
136
47.89%
Voters: 284. You may not vote on this poll
7.0 or 6.2 S/C
7.0 or 6.2 S/C
If you had your choice--would the top engine Camaro be--the 7.0 or 6.2 S/C?
I'd take the 7.0--aka 427. It has heritage and cache. I mean Ford has to S/C there V8s to get them to go----Gm has never had to!
Why start now?
Add VVT and DI to the 427--get the costs down and drop her in, GM!! Yeah I know it's not gonna happen
Why start now?Add VVT and DI to the 427--get the costs down and drop her in, GM!! Yeah I know it's not gonna happen
Size matters
Do you want 6.2 on viagra, or 7.0 going strong, all natural?
Ok, but seriously, I like the ring that 427 c.i. has to it
. And I don't care if "the LS7 is dead after '08" or whatever. Just because a 3-letter designation is done, doesn't mean that displacement can't be used again
. How many designations did the 350 SBC have over it's life?!
Way too many to list!
Give us an LS7 derivative ... not "THE" LS7 ... just the same long block. The dry sump system can go ... a traditional oil pan will suffice
. It has all the same outer dimensions as an LS1/2/6, so there's no issue FITTING it in the car. And if it's MASS produced vs. limited build like the current C6Z, then the cost shouldn't be much more (unless they stick with the titanium internals, which again, could be substituted for cost purposes, if necessary).
That's my $.02
.Do you want 6.2 on viagra, or 7.0 going strong, all natural?
Way too many to list!Give us an LS7 derivative ... not "THE" LS7 ... just the same long block. The dry sump system can go ... a traditional oil pan will suffice
That's my $.02
I tend to come fromt he school of "pure displacement over force fed air"; however, if the numbers that people are speculating do turn out to be true with the 6.2, then 600+HP would be hard to argue with regardless of how you get the result. Odds are if i were to buy either option (which I have no intentions of doing anyway) I wouldn't mod either of them anyway, so I would prefer the option with the highest initial HP.
Personally, I would like to put 625HP on the cowl instead of 427ci.
Well the 7 litre is nice but if I can have similar power form a cheaper motor and make a simple pulley swap to add another 50-100hp I'll take the 6.2 supercharged, can't do that with a naturally aspirated engine without a lot of money. Plus the 7 liter is already running really high compression so no aftermarket supercharger without changing pistons.
That's my $.02
That's my $.02
I feel like the debate over S/C 6.2 vs. N/A 7.0 is fairly easy to solve. Do a quick search of these boards and find out what kind of respect the 04 Mustang Cobra gets. That thing puts out over 550 RWHP with a tune, exhaust, and simple bolt-ons. You never even have to change the cams or heads. That's from a 4.6 OHC motor.
Our motor has about 95 more cubic inches, and is a platform that has made more HP per CI than Ford motors since about 1955. Okay, okay, I exaggerate... but you get the point. We definitely whoop *** HP per CI on the modular NA 4.6/5.4.
If we get a blown small block from the factory, we could seriously be looking at 700 Rear Wheel Horse Power for the cost of the car plus about $2500 to $3000, and that's if you pay someone to install the exhaust.
How many of us would like to buy a car, spend less than 10% of the purchase price in mods, and be able to absolutely destroy almost anything on the road? There isn't a Mustang out there that's anywhere near stock that could compete with that, not even their "Terminator".
Hell, most Ferrari's, Porsche Turbo's and SL65's would have trouble competing with that.
