largest wheel and tire on 92 camaro
Old 07-06-2016, 01:00 AM
hghpwr's Avatar
hi guys,
a friend of mine from work bought a 92 Camaro,383 700r4 373 gears ,and wants too turn it into a serious street and drag car some day.
wanted to buy some rims and he bought some 8" wide 4" backspace from summit . told him you should be able too get a much wider rim and tire and he did not believe me. can anyone tell me what can fit with stock wheel wheels. I think at least a 9.5 " wheel and a 10.5 " tire
hghpwr is offline
Old 07-06-2016, 10:44 AM
Re: largest wheel and tire on 92 camaro
Indirect answer, but may help. There is a "sticky" thread written by a guy who put wider tires/wheels on an 89. I doubt you are looking at the diameter wheels he used (18 x 8.5" front; 19 x 10.0" rear), but the important piece of data is the width of the wheels and the width of the tires.
Front he ran 255/40-18. That's a 26.0" diameter tire with a 10" section width. In the back he ran a 295/30-19. That's a 26.0" tire with an 11.6" section width.
Unfortunately, the links to the photos no longer work, he was running a 4th Gen rear, which is 3 to 4" wider than the 3rd Gen, he was using extremely large offset OEM Corvette wheels, and got into issues with spacers, etc. Yours will be closer to 0 offset, but maybe someone could fill us in on the correct offset (or backspace).
https://www.camaroz28.com/forums/whe...wheels-622922/
Injuneer is online now
Maroz28maro
07-29-2016 07:45 PM
AtlasXVIII
08-02-2015 10:29 AM
warmeck
06-05-2015 05:19 PM
Geeterman
08-04-2002 04:03 AM
ollie-99
06-20-2002 08:55 AM
Quick Reply: largest wheel and tire on 92 camaro
