15x8 prostars up front
Old 12-08-2013, 04:58 PM
97s10ondubs's Avatar
Will this work? What size back spacing? I tried searching but couldn't find an answer. I'm tired or driving on the 3.5" on the street. Thanks
97s10ondubs is offline
Old 12-09-2013, 09:57 AM
Re: 15x8 prostars up front
The stock 8" wide wheels have about a 6-5/8" backspace. You want to see if they make a 6.5" backspace in the Welds. You will still need the spacer if you are running one (I needed a 5/16" spacer with my 15x3.5's). The slighly smaller backspace, plus the thickness of the spacer will move the wheels outward almost 1/2" compared to stock.
You might be able to live with a 5.5" backspace, but with the spacer, that's going to be outside the fender.
Injuneer is online now
Old 12-09-2013, 03:34 PM
Thanks. Do you think it would be better to go with a 6" or 7" instead? I don't see the 8" in any bigger than 5.5" backspace. The 7" comes in 5.5" backspace.
Old 12-10-2013, 07:21 AM
The 7" wide wheel with the 5.5" backspace will work OK. That will produce the same "front space" as the 8" wide wheel with a 6.5" backspace. With a 5/16" spacer, the outside edge of the wheel/tire will be about 1/2" further out toward the edge of the fender than the stock wheel. I have run wheels with 1" more front space than the stock wheel, and they worked fine... maybe a little rubbing on the inner plastic fender with the wheels at full lock.
I also checked the Pro-Star 3.5" wide wheels, and they also have the outer edge of the wheel/tire at the same location at the 7" wide/5.5" backspace wheel will have.
Old 01-18-2014, 07:19 AM
What's the tallest tire you think I could run up front? I want a little more ground clearance. I'm scraping the crossover pipe on bumps. I still have the stock SS springs, I think they are like 0.75" lower.
Old 01-18-2014, 07:55 AM
Do you have hubcentric spacers? I'm running some that I got from a friend with the pro star wheels, but they are not hubcentric. Trying to find some online if you know who has them, that info would be great.
Old 01-18-2014, 04:35 PM
I run 26" Moroso DS-2's in the front, but that's a 'skinny'. I think my front end is down slightly from stock (QA1 adjustables).
You could use a 245/60-15 at 26.6". Perfect for a 7" wide wheel. Adequate load rating (1,700+ #). BFG makes a Radial T/A all-season in that size. They also make a 255/60-15 at 27.1" diameter. Recommended wheel width is 7.0 - 8.0". Then, for a skinnier look, there's a 225/70-15 at 27.4" . Or a 215/70-15 at 26.9".
I got my spacers years ago from Skulte Designs. He made great adapters and spacers, custom dimensions if you wanted them. But he gave up the business about 5 years ago. I see people buying stuff on the 'net, but I have no idea of the quality.
96SilverRam
11-20-2016 11:19 AM
Jasonz28camaro
06-07-2015 09:14 PM
Jasonz28camaro
West South Central
06-07-2015 09:12 PM
8T8IROC
03-26-2015 09:02 PM
mongoose=
03-22-2015 07:22 AM
Quick Reply: 15x8 prostars up front
