80mm LT1 front mount turbo setup FS in DFW
i have a complete 80mm front mount turbo kit i pulled off a 93 camaro Z28 with a blown headgasket. the turbo kit is in perfect working order, it just needs a new home
it includes turbo, headers, blow off valve, waste gate, intercooler, all hot and cold side piping, K&N air filter, oil plumming, tapped LT1 oil pan, accessory delete setup (you will have to delete your ac compressor and power steering pump to make room for the turbo), battery relocation setup, and radiator supports. this is everything you will need to install it in your LT1 93-97 trans am camaro or firebird.
it currently has a 9PSI spring but is capable of makeing much more boost if needed
asking $2300 for everything
please pm me if interested or e-mail me at f-bodyparts@hotmail.com
thanks
robbie
thanks
robbie
10-31-2016 11:09 AM
1LEThumper
07-14-2003 12:45 PM
