OMG i'm changing my spark plugs
Old 03-31-2013, 12:45 AM
  #31
fbodyrs96's Avatar
Re: OMG i'm changing my spark plugs
get headers, no more spark plug problems...
an NKG TR55 our the most popular for the 3800, check any v6 site.
fbodyrs96 is offline
Old 06-14-2014, 03:20 PM
  #32
TC94Z28's Avatar
Bumping an old thread here, was afraid to even try after reading all this... The only problem I had was with #4.. It was one I had to get the socket and extension on from the bottom and then go up top to fit on the ratchet.. Took a lil under 2 hours to swap them all out and change a couple of my coils that looked kind of ugly and corroded..
On a similar subject I bought some 10.5 wires from ZZ performance.. At this time I would not purchase a set if anyone is looking in to them....I was told they would fit by a rep of theirs on eBay, and there is not a chance that they will.. #1 is way too short and can't even work on cyl #5 which is closest to the coil packs..
The wires I received are obviously for front wheel drive only!!
Sent from my iPhone using Tapatalk
TC94Z28 is offline
Old 06-15-2014, 05:43 PM
  #33
There is no reason to run 10.5mm wires, unless you've got some sort of 1,000 + HP setup with a killer ignition system.
Injuneer is offline
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
Dark Zeiro
03-11-2015 07:15 AM
jasonduaine
03-07-2015 09:44 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
Dan_the_ManZ28
02-21-2015 02:01 PM
Quick Reply: OMG i'm changing my spark plugs
