car starts....sometimes
Old 02-27-2013, 11:40 AM
driving mad's Avatar
I just started having this problem, where my Camaro doesn't want to start. I have full power to everything, radio, lights, horn, blah blah blah. But when I go to crank, I hear nothing, except the fuel pump engaging. Sometimes I can play with the battery connection while someone is trying to start it until I can hear the starting trying to grab, but I haven't even gotten that. I have checked all the connections and everything is connected like it should be.......I get frustrated and leave the car sitting for a few hours, come back and the car starts right up. I am extremely baffled, please help me figure this out.
driving mad is offline
Old 02-27-2013, 06:58 PM
Jackness89's Avatar
Re: car starts....sometimes
I bad a similar problem with my 97 3.8 turns out it was something on the steering column was burnt. Im sorry I don't know the name of the part but when the key is turned it pushes a metal down the Column into this device.
Jackness89 is offline
Old 03-05-2013, 12:08 PM
Super Moderator
JakeRobb's Avatar
Sometimes the side-post connections on GM batteries go bad. Make sure your cables are connected connected tightly, and try a different battery. A continuity tester will often not show the problem, since there's enough connection for that little trickle of current, but not enough to turn a starter.
JakeRobb is offline
Old 03-05-2013, 06:21 PM
brandonppr's Avatar
Do you have a chip on your key?
brandonppr is offline
Old 03-17-2015, 12:25 AM
Darth_tsunami's Avatar
Do you by any chance at all remember what it was called?
Darth_tsunami is offline
Old 03-17-2015, 01:26 PM
The key cylinder is connected to the ignition switch by a rod... sounds like what he is describing.
4th Gen F-body Ignition Switch Replacement
Injuneer is offline
Old 03-24-2015, 02:28 PM
ZeeS7o7's Avatar
its 2015, I hope he fixed it by now or got a V8 lol
ZeeS7o7 is offline
Old 03-24-2015, 09:13 PM
I think the recent post was from someone who did a search, and for some reason needed a part name. I don't think he was trying to help the OP.
Injuneer is offline
Old 03-25-2015, 10:44 AM
ZeeS7o7's Avatar
I didn't read all the posts in this thread...my bad
ZeeS7o7 is offline
Jazsun
12-29-2014 12:14 PM
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: car starts....sometimes
