Alternator not charging after changing serpentine belt
Old 01-30-2013, 03:46 PM
Magesh Kumar's Avatar
Hey Guys,
I changed the drive belt myself last evening. Since then the alternator doesn't seem to charge the battery? I check if the belt is tight and it is. I can even see the component inside the alternator running. Any help would be appreciated.
Magesh Kumar is offline
Old 02-03-2013, 11:24 PM
kallcium's Avatar
Re: Alternator not charging after changing serpentine belt
First check the serpintine belt routing, if the routing is not correct and for some reason the altenator is spinning backwards it may cause your problems since you just changed it. Second check all the wire connections, battery cables, etc to ensure that nothing is loose. If all this is good then you probably have a bad altenator and just a weird coincidence that it happened at the same time you changed the belt.
kallcium is offline
Old 02-04-2013, 10:41 AM
Thanks for the reply. I figured out that alternator went bad. I've to agree that was a weird co-incidence.
AlaskaZ28
04-17-2015 08:54 AM
grabbem88
02-23-2015 09:41 PM
SpeedJunkee
01-27-2015 10:02 PM
Oncomingstorm22
01-22-2015 07:15 PM
Snoman73
11-17-2014 07:22 PM
Quick Reply: Alternator not charging after changing serpentine belt
