700R4 question
Old Mar 24, 2003 | 08:45 PM
slayer6x6's Avatar
700R4 question
just replaced the trans in my 91 z but the problem is that when its in drive or od the trans slips between gears and shifts real sloppy but when i manually shift from first to second and from second to drive its shifts great! any ideas?? btw the tv cable is adjusted right. thanks for any help!
Old Mar 24, 2003 | 08:53 PM
kjlvilla's Avatar
What's your pressure at idle in gear. It should be at least 80 psi. If not then your t.v. cable is probably stretched and an adjustment will not help. Try pulling the cable through and adding a small split shot sinker or zip tying a tie wrap before the crimped stop on the end. This should take about 1/4" away from your cable and tighten up your shifts. If this helps then replace your cable or leave the "band-aid" in place. There isn't anything in common in 2nd or 3rd other than your forward clutch. If this was bad then all gears would slip, even manual gears. Good luck.
Old Mar 24, 2003 | 11:23 PM
fbird95's Avatar
My 88' caprices 700R4 always had that issue since it was new. After a while you just get used to it. sometimes i would just leave it in 3rd, drive so it wouldnt sloppily shift from 3rd to 4th and back.
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
