10W6 Questions
Old Feb 20, 2003 | 09:25 PM
xmatt's Avatar
10W6 Questions
I just bought one and am constructing a system to put it in. What size amp do i need? the speaker is rated at 1000watt, with 300watt continuous power.
Thanx
~Matt
Old Feb 20, 2003 | 10:58 PM
firebirdude's Avatar
continuous power (RMS) is the only power that matters.... What type of box is it going to be in? Shoot for a 400WRMS amp.
Old Feb 21, 2003 | 05:25 PM
xmatt's Avatar
ty is going into some type of stealthbox. It should have an area of .5-.6, which should be sufficient.
I only wish I could get one for less that $100 seeing as how I only spent 90 on the speaker.
Do you have a specific amp that I could look the specs up for so that I would have a good idea what I am getting into? I am a real nOOb when it comes to audio stuff.
Thanx,
~Matt
Old Feb 21, 2003 | 06:37 PM
First thing you should know is that the whole W6 line comes with dual 6 ohm voice coils. If you are only using one subwoofer, you will want to wire the coils in parallel. This will present your amp with a 3 ohm load. So you will want an amp that puts out 300-400WRMS at 3 ohms.
Does that mean that you want to spend $100 on the amp? If so, your gonna have some trouble powering your sub to it's fullest. One of the best bangs for the buck right now is the JBL BP600.1 This will output over 600WRMS into a 2 ohm load. Since you will be running at 3 ohms, probably around 400WRMS.
Old Feb 22, 2003 | 03:40 PM
xmatt's Avatar
Thanx so much firebirddude. I guess it is gonna have to wait till my birthday.
~Matt
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Wilson
Jul 21, 2002 04:58 PM
