Unusual OBDII to OBDI question...
Old Feb 5, 2003 | 08:16 PM
96z's Avatar
96z
I want to swap my car from OBDII to OBDI. Im going to get the knock sensor, and no longer have the rear O2's. My friend has a multicar version OBDI EDIT that I can have access to....
So how can I use his LT1 edit with my OBDII connector under the dash. Arent the cables locked to the LT1 edit?
Thanks
Old Feb 5, 2003 | 08:53 PM
madwolf's Avatar
No,
the OBDI version doesn't have a lock on the cables. You can use his cable/program as long as he has a 95 style connector...
Old Feb 5, 2003 | 10:48 PM
96z's Avatar
96z
Originally posted by madwolf
No,
Sorry I misunderstood. How is his 95 connector useful if I have a 96 connector??? Are they the same?
Will it work If I get a akm OBDII to OBDI cable and use his hardware(OBDI edit)??
Old Feb 5, 2003 | 10:49 PM
madwolf's Avatar
95 connector is the same as the 96+ ones.
94 and earlier connectors are different.
If you wanna get a cable from AKM, just tell Andrew that you have an OBDII car converted to OBDI and you want a cable for it.
Old Feb 6, 2003 | 03:23 PM
96z's Avatar
96z
Cool, thanks. Looks like Ill get off easy with just a PCM and cable than.
autoxr166
Sep 25, 2015 04:21 PM
aj2494
Mar 12, 2015 10:17 PM
SnkEatr
Feb 9, 2003 09:56 PM
LTOne4Fun
Sep 1, 2002 05:31 PM
Dan K
Aug 3, 2002 09:12 AM
