2000 Z28: Security light on dash
Old Jul 27, 2010 | 05:03 PM
BoneDaddy500's Avatar
I have a security light on and I can't figure out how to turn it off.
2000 Camaro z28
Old Jul 27, 2010 | 05:08 PM
JakeRobb's Avatar
Super Moderator
Moved to General Tech. You will have better luck getting an answer here, as the problem is not engine related.
Generally this has something to do with the VATS system, which is the little chip in the ignition key (and the part of the car that reads it). I'm afraid I won't be of much help personally, but if you search this forum for VATS, you'll probably find some helpful advice.
Old Aug 6, 2010 | 12:16 AM
Don350k's Avatar
yep its a vats prob
Without a code reader that can access the bcm its impossible to know for shure, but usually it means that the BCM is not reading the correct or any frequency from the key
try usuing a eraser on the keys chip this sometime helps.
Old Aug 6, 2010 | 07:55 AM
shoebox's Avatar
http://shbox.com/1/pass_key.html
Old Aug 6, 2010 | 11:45 AM
Don't over-rate the "chip" and assume it emits "frequency". It's a simple resistor pellet.
moparman
Mar 5, 2015 08:47 AM
jayvar
Feb 2, 2015 10:00 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
