[Electronics/Car Audio] HID Problem
Old Jul 22, 2010 | 08:38 AM
avigno30's Avatar
HID Problem
Ok, so I have a non-rs LT1 and just purchased a single beam hid conversion kit ( http://www.vvme.com/12v-5055w-h13-hi...cPath=44_45_29 )
It didn't come with a harness type connector to connect the light to the car, instead it just has the two wires with crimp on pins so i connected it that way, the problem is when i turn the light on, the lights just turn on for about a second or two then dim out and shut off.
Any help would be greatly appreciated.
Old Jul 22, 2010 | 02:22 PM
jcamere94z28's Avatar
i recommend you call them?
Old Jul 22, 2010 | 03:44 PM
avigno30's Avatar
I tried that, they wanted me to ship it back, but its based out of hong kong and would be more expensive to ship back then buy new ones, but if it turns on for a second doesn't that mean the bulb is working?
Old Jul 22, 2010 | 04:29 PM
SSPORT10's Avatar
Sounds like the system is either bad or you do not have it hooked up correctly. I purchased a HID conversion system from Ebay for my Traverse that came with the digital balists and just plugged right into the wiring harness from the headlilghts. They work awesome and they were from a US seller.
Old Jul 25, 2010 | 02:51 PM
JasonD's Avatar
Admin Emeritus
If they are defective, they need to cover the cost to ship them back.
I am always wary or buying anything direct from China.
Check and double check your wiring. If there is any doubt at all, have a pro look at it.
Old Jul 26, 2010 | 03:05 PM
avigno30's Avatar
Soooo, you can all make fun of me now, finally realized I had the polarity backwards in the direction i plugged the wire into the ballasts
Old Jul 26, 2010 | 03:07 PM
JasonD's Avatar
Admin Emeritus
Happens to the best of us. Glad you got it worked out!
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
XtremeLt1
Sep 13, 2002 08:50 PM
2002Z28SSConv
Aug 6, 2002 02:15 PM
Mad_Ice
Jul 29, 2002 09:44 PM
