fuel lines melting
Old Jul 17, 2010 | 11:32 PM
donaldsz28's Avatar
fuel lines melting
how do you guys keep your fuel lines from melting? My lines are getting roasted where they go from metal to plastic.
Old Jul 18, 2010 | 01:48 AM
jasonface's Avatar
The easy response would be "keep them away from heat sources". It sounds like your LT's are close enough underneath to hurt them...very bad news. If re-routing the lines is not possible, you may have to make up some shielding. Shield the lines themselves with something like spark plug wire heat shields, then maybe even do a thin metal shield between the header and the lines. You can attach a shield anywhere in that area very easily with some small self tapping screws. Get some thin sheet metal (.040 would do) and bend it up to fit between the LT and the lines. Hopefully you have a least 1"-2" to work with between the lines and the header.
Old Jul 18, 2010 | 02:00 AM
donaldsz28's Avatar
I thought about making a heat sheild but i just figured it would get hot too.
Old Jul 18, 2010 | 02:12 AM
jasonface's Avatar
The shield will reflect a significant amount of heat, and will dissipate some more as well. There will be much less heat on the lines side then the header side for sure. A double shield with the walls .5" apart would knock it down considerably more, if you need to.
Old Jul 18, 2010 | 02:15 AM
jasonface's Avatar
Thought about one more thing. If your headers are not coated, getting them ceramic coated would help tremendously, but it's not cheap.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
91Bird305
Aug 5, 2002 01:39 PM
