LT-4 With Hot Cam using LT1 edit. How much can you advance the timing?
Old Jan 30, 2003 | 08:04 AM
GSLT-4's Avatar
Hi, I have a lt-4 383 stoker with LT-4 Hot Cam. I had the OBD II computer tuned by a local tuner. He left the timing stock LT4 except for the 4000 to 6000 rpm range. He advanced the 4000 to 6000 range 2 degrees. He ran auto tap after that and did not pick up any knocks. Does any one have a similar set up and did you program it with lt1 edit? How far did you advance your timing and how much at what RPM ranges?
Thanks, Michael
parkers Z28
Mar 11, 2016 08:14 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Noenav
Dec 6, 2014 07:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
