how to replace mass air flow intake ?
Old Nov 18, 2009 | 08:07 AM
dallas63's Avatar
i have a 1996 camaro z28 with the lt1 ? the shop told me that i need a mass airflow intake . how hard is this to put on and the average price . they want to charge 400 . thanks for any help
Old Nov 18, 2009 | 08:45 AM
Sick97SS's Avatar
Why don't you try cleaning it first? (Take out, take apart, and clean tiny sensors) They have MAF cleaner at most auto stores.
My car ran like new after cleaning it.
Old Nov 18, 2009 | 02:18 PM
shoebox's Avatar
Post more info on your problem. $400 is absolutely ridiculous.
Old Nov 18, 2009 | 05:01 PM
What was the problem that caused you to take it to the shop?
Was the SES light on? Did they do a PCM scan, and advise you of the specific codes they found? If not, how did they determine the MAF sensor (if that's what they mean by "mass airflow intake") needed to be replaced?
You can install an MAF sensor yourself, in about 10 minutes, with no tools other than a screwdriver. The cost of a new MAF sensor should be a fraction of the $400 they quoted you.
You need to clarify with them - what are they replacing? The "intake" is the entire air system, from the inlet air box/filter, to the throttle body. The "mass airflow" sensor is one compenent in that system.
Old Nov 18, 2009 | 08:56 PM
dallas63's Avatar
about a month ago, these are a list of the repairs that I had done:
tune up-replaced water pump distributor/rotor plugs wires crank censor
replaced radiator and replaced intake manifold
Everything was running fine until a little over a week ago. When accelerating it had a hesitation or dead spot. It would turn over but wouldn't start. A friend of mine took off the air filter and sprayed carb cleaner up through it and it started right up. Then I was driving and it died three times. It acted like it lost complete gas pressure.
So I took it back to the shop and they are saying that it is the mass air flow intake. All help is appreciated.
Old Nov 18, 2009 | 09:11 PM
oneclean97z's Avatar
if that's exactly what they said, "mass air flow intake" then they need to go get certified. they're either saying you need a whole new intake setup, which you more than likely never will, or just the mass aif flow assembly, which should never ever cost $400 to do on a 96 camaro. try taking it off with screwdrivers and spray cleaning it with cleaner from autozone etc
Old Nov 18, 2009 | 09:46 PM
dallas63's Avatar
yes sir exact words . i thought it was called a mass air flow sensor . would that becausing my problems
Old Nov 18, 2009 | 10:12 PM
Could be as simple as a torn rubber inlet elbow. Check for tears, and possibly the bottom edge of the elbow not pushed fully on the throttle body.
Has anyone checked the fuel pressure?
Don't be spraying "carb cleaner" on anything. Its way too harsh. There is an anti-coking coating on the throttle body blades that can be removed by carb cleaner. Use "throttle body cleaner".
Old Nov 18, 2009 | 10:43 PM
dallas63's Avatar
k will look at elbow
Old Nov 19, 2009 | 09:28 AM
Dude clean your mass air flow sensor too. The cleaner spray is cheap, make sure it's one made specifically for that though
Old Nov 19, 2009 | 09:50 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
400 bucks to install a new MAF? Are they supplying the lube, or do they expect you to bring your own? If you do end up needing a replacement, you can buy a new one for a fraction of 400 bucks and install it yourself. It would be difficult to screw it up.
Old Nov 19, 2009 | 10:25 AM
dallas63's Avatar
thank you all will try everything and let you know .
Old Nov 19, 2009 | 11:35 AM
MikeGyver's Avatar
You REALLY need to find a new shop.
Old Nov 19, 2009 | 01:28 PM
brianswimmer23's Avatar
did you get it figured out???
Old Nov 19, 2009 | 07:29 PM
dallas63's Avatar
not yet . my son had ball practice . i am buying the cleaner 2mrw and try it . thank you all very much . will let you know
