taylor 8mm or 10.4mm plug wires?
Old Nov 9, 2009 | 06:46 PM
c5formula's Avatar
which set should i got with? my car is running the valve cover mounted Delteq setup so ima have to get the universal set an cut them to length. i just have a chance to get both at the same price an wanted to know which would be best for my setup?
Old Nov 17, 2009 | 02:39 PM
MysticBowtie's Avatar
I'm about to do the same thing, where are you getting them?
Old Nov 17, 2009 | 08:46 PM
c5formula's Avatar
from a company off ebay
Old Nov 18, 2009 | 07:42 AM
The Untouchable's Avatar
get the 10.4's there better the core "wire" seems to be a lil thicker and there much better heat resestant and much less chance of electrical seepage and breakdown, also i have run the 10.4's and 10.5's of other brands to on other sbc build and it seems they last a hell of alot longer.
and the resistance in the wires seems to stay low even with high mileage .
try to get some with "ferro core" but if you get ferro core's becareful not to twist them real hard cus u will break the core
Old Nov 18, 2009 | 07:44 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I've always heard that MSD makes a better wire.
Old Nov 18, 2009 | 03:52 PM
i have had good luck with msd wires and the accel 300+ ferro core wires
Old Nov 21, 2009 | 08:05 AM
rskrause's Avatar
No advantage to those huge diameter wires.
Rich
Jazsun
Dec 29, 2014 12:14 PM
GigaMp3z
Feb 20, 2003 02:57 PM
70rs00z-28
Sep 6, 2002 08:13 AM
