thinkin bout goin to the ltcc setup! anyone heard anything bad/failures?
Old Nov 8, 2009 | 11:14 PM
4SFEDZ's Avatar
ok, my opti crapped out with very low miles! at 14psi it made 670 thru a th400 and big stall, and ran 6.2 in the 1/8 the 2nd time out. just wanting some input on the system on FI cars!
Old Nov 8, 2009 | 11:32 PM
Ultra_Dog's Avatar
I have the Delteq system and am very satisfied. Although the "Brain" is susceptible to heat and needs to be insulated. Unfortunately, Delteq isn't made or supported anymore, (as far as I know).
But it does the job and I haven't had to mess with the Opti ever since. I can assume the LTCC is equivalent.
Of course, there is no additional power from this setup, as the coils are stock GM parts.
Old Nov 9, 2009 | 09:55 AM
ramair96ws6's Avatar
Best Ignition I have ever had on the car 100% reliable.
Here is my LTCC Setup. It gets questions everytime!
Old Nov 9, 2009 | 11:57 AM
mzgp5x's Avatar
I had numerous opti failures with opti sonic welded rotors. My app... 97ss 383 D1 MM6 with MSD 6A/ 8202 coil. To hot for the stock rotor brass electrical mfg mount. I fixed (with no rotor failures ever) by adding two (2) alum 1/8" rivets and filing for clearance. I had a NEW gm opti rotor fail in 1+ weeks. Summit allowed me to return. So, you could say, I always void my NEW purchase warantee, or, call for the tow. HTH. B.
Old Nov 9, 2009 | 01:48 PM
4SFEDZ's Avatar
what wires you runnin? they say on the website that low resistant wire can cause problems!
Old Nov 9, 2009 | 07:07 PM
joe-96z1le's Avatar
I'm using Magnecor wires with my LTCC. They work good and you can order them in custom lengths.
Old Nov 9, 2009 | 10:00 PM
Moroso ultra 40 wires and have never had an issue
Old Nov 9, 2009 | 10:57 PM
The Untouchable's Avatar
hey that is one sweet setup and car ,if ya dont mind would you pm me what parts i would need to do a LTCC setup and where to get the parts and any part #'s if ya gotem. thanks in advance.
also by the way ACCEL makes high performance DIS coils for that type of coil
there about 20 bucks each
Old Nov 10, 2009 | 07:50 AM
DirtyDaveW's Avatar
I bought my LTCC back in 2003. All during that motor (355) and the subsequent Solid Roller 383, it performed flawlessly. I had a '94 Z28 for a while as well as my original owned 96 Z28. The opti on the '94 seemingly went out. I pulled the LTCC of my '96 and put it on the '94 in about 20 minutes. The '94 fired right up and ran perfectly. They are a great addition to the car. Just get the right plug wires, be SURE to wire it correctly. There has been the occasional Opti harness connector oddities(channel or the rib going throught the channel not compatible) but they are easily fixed with a dremel. The new LTCC's use the factory LS1 Coil Wiring Harness. My original one had one wire loom with several wires for each coil. Ugh... Looked like a bag of snakes in my engine compartment. THe new version is much cleaner, having one split loom per engine bank.
Old Nov 10, 2009 | 08:14 AM
97WS6SCharged's Avatar
Hmm... sounds like it's time to call Bob and get an updated harness for mine. I hate trying to fit all those wires under my fuel rail covers.
Old Nov 10, 2009 | 09:23 AM
DirtyDaveW's Avatar
Here's my original LTCC from 2003. Look at picture #3 to get an idea of the wiring harness.
http://www.taekwondoplus.org/z28/LTCC.htm
Now look at the new one I bought a year ago...
Hmm, I see the 'resizing' of that picture on this site removes the ability to read the captions. Here's the link to the full size picture/text.
http://www.taekwondoplus.org/z28/NewLTCC.JPG
Old Nov 10, 2009 | 09:48 AM
Yea Bobs a great guy he saw pictures of my set up and then stole my idea from this site.... Maybe stole is a strong word maybe ganked would be better lol
Old Nov 10, 2009 | 10:25 AM
Do you have a diagram to do this to the old harness? I talked to Bob a few minutes ago and the price for the new harness is a little steep to replace something that works.
Old Nov 10, 2009 | 11:26 AM
jsetzer's Avatar
My vote still says its an expensive system that still relies on the opti.
I like solutions that eliminate it.
Old Nov 10, 2009 | 01:25 PM
What did he want for the new harness?
