Is ecm bad?
Old Nov 8, 2009 | 01:41 PM
edz97's Avatar
Is ecm bad?
I installed a 96 lt1 Z28 into my 97 Z28. The computer and wiring was in the car when I bought it non running. I have everything hooked up and it will not start. New opti, new fuel pump 45 psi at the rails. The noid ights are not lighting. I plugged a scanner into the obd11 port and it's reading error in comm can not link...... Is it a bad ecm?
Old Nov 8, 2009 | 04:37 PM
Check the cig lighter fuse to insure you are getting power to the ALDL connector.
Old Nov 8, 2009 | 05:39 PM
edz97's Avatar
I'l check that, thanks.
Old Nov 8, 2009 | 09:15 PM
edz97's Avatar
cig lighter fuse ok and I plugged a cell phone cord to verify power.
Old Nov 11, 2009 | 02:52 PM
mark97ta's Avatar
you need to check and make sure you have power at the injector connectors, it's the pink wire, the pcm grounds to open injectors, there are two 7.5 amp fuses in the exterior fuse box, also look in the in the interior fuse panel for a pcm fuse, it provides constant voltage to the pcm...
Old Nov 12, 2009 | 07:12 AM
edz97's Avatar
I will check the wires. What effect does the crank position sensor have on starting.
Old Nov 12, 2009 | 11:18 AM
shoebox's Avatar
Nothing. It is only used for misfire detection on an LT1.
Old Nov 12, 2009 | 11:24 AM
jay_rich's Avatar
i had an issue like that, car would run but wouldnt flash, sent it to PCM forless and got it socketed.
What happened was I was tuning and the battery cable was loose and killed it.
Jay
ducttape1975
Jul 10, 2015 06:29 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
