Quick turbo question
Old Nov 5, 2009 | 02:25 PM
1977maroman's Avatar
I'm beginning aturbo build on my 1977 Camaro... I have a good amount of auto knowledge, but I'm still learning about turbo specs. Any ideas on a turbo that will build boost at a lower RPM. My max rev is around 4,800 RPM...
Thanks for the input
Old Nov 5, 2009 | 02:32 PM
chasmosis1's Avatar
I am only somewhat familiar with turbos, but I do know that the smaller the turbo the less the lag and the sooner the spool. A higher quality turbo would have less lag as well.
Chas
Old Nov 5, 2009 | 03:04 PM
97FormulaWS-6's Avatar
What are you putting in that thing, a diesel? Redline to 4800rpms?!?!?!?
Need a lot more information on your engine and goals before we can recommend anything.
Old Nov 5, 2009 | 03:12 PM
reamo04's Avatar
need a lot more information. I could recommend a turbo not knowing what motor it is or specs, and on my motor it'd have full boost by than but your motor who knows.
Old Nov 6, 2009 | 01:30 PM
Specs
Specs on the engine:
-5.7L running 8.5:1 compression
-If I take it over 5K I get some valve float, so some stiffer valve springs are in order. I'm not sure where that will take my rev range to so I just put in what I had.
-I'm not sure what internals I have seeing that the engine was rebuilt by someone else, I'm guessing the pistons are hyper nematic. it has about 45-50,000 miles on it.
I'm not sure what else ya need, but just ask for specifics.
Thanks for the quick response!
Old Nov 6, 2009 | 01:59 PM
reamo04's Avatar
hypereutectic pistons are not going to like boost much and will be very prone to failure.
What are your power goals?
I can suggest a T60 or something along those lines, it will spool fast and give you full boost probably 2200 or so. However, it will also probably run out of steam at about 500 at the wheels
Old Nov 6, 2009 | 02:06 PM
MikeGyver's Avatar
Hypereutectic pistons just just don't like to run lean (too much heat), and they don't like detonation.
You should never allow either of these cases in Any setup. Hypereutectic pistons are just fine for 400something HP if tuned correctly. Tougher forged pistons give you added safety and more leeway.
LeftoverChinese
Jan 14, 2024 03:03 PM
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Brady
Jul 29, 2002 10:30 PM
