no spark need help! car wont start!
Old Nov 2, 2009 | 04:23 PM
4SFEDZ's Avatar
ok went racing then the next day came out started the car, backed it off the trailer, shut it off and now it wont start. ive checked for spark and nothing. i think its either the opti or comp! how can i test to see if its either or? i pulled the ecm conector and all the voltage is good there!
Old Nov 3, 2009 | 01:18 PM
4SFEDZ's Avatar
come on someone,,,,, i folowed shoebox's "http://shbox.com/1/4th_gen_tech2.html#opti_test" and im getting the 10v on the "a" and "d" terminals. but nothing on the "b" terminal. checked the plug goin into the opti and it looked good. so i think its the computer or opti. anyone know a way to test each one? i dont have access to a scanner and i did the paper clip jump and go no blinks,
Old Nov 3, 2009 | 03:49 PM
SoloExceptional's Avatar
Be sure you did the test on B while cranking and on an AC setting. Also make sure the connector is on the opti when you test. If you get nothing from B but something from A, According to Shoebox's website means you lost high res signal or your meter doesn't update fast enough. Are you using a digital multimeter? Also I would check the ignition fuse.
Old Nov 3, 2009 | 04:12 PM
Borrow an OBD-I scanner and check it for codes. 93 was the last year you could short the ALDL connector to flash the codes. That will tell you if the optical cam position sensor has failed.
Noenav
Mar 1, 2019 07:38 AM
Noenav
Dec 6, 2014 07:35 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
