Spohn tq arm rubber gaskets
Old Oct 29, 2009 | 07:31 PM
z28_4life's Avatar
The stock ones seem pretty thin and flimsy. Has anyone upgraded this piece with a thicker one? If so what did you end up using? I'm thinking autozone might carry gaskets that you can trim to fit.
Old Nov 2, 2009 | 10:25 PM
Z-RATED94's Avatar
Do what you want but it's still going to transfer road noise and the occasional clunk when you first take off. It's just the nature of the beast and I really don't mind it that much. Make sure you use grade 8 bolts.
Old Nov 3, 2009 | 04:30 PM
z28_4life's Avatar
Well, it sounds as though your running the tq arm as well. I understand that there will be road noise and the occasional clunk but upon inspecting the gaskets that come with the tq arm I would venture to say that two pieces of paper stacked together are thicker than what is provided
Old Nov 4, 2009 | 05:36 PM
Z-RATED94's Avatar
I can't argue with that. I thought about what you mentioned, but the bolts for the cross brace will transfer the vibration to the chassis anyways.
Old Nov 4, 2009 | 06:35 PM
z28_4life's Avatar
Yea, the tq arm has seen 700 miles and the gaskets looked a little bit used after two installations/removals so I was either going to replace or upgrade.
DarkKnight
Buyer/Seller Feedback
May 4, 2015 03:32 PM
derty
Sep 12, 2002 04:45 PM
derty
Sep 9, 2002 11:52 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
