o2 sensors draining power?
Old Oct 18, 2009 | 04:17 PM
TM2S3's Avatar
Not too long ago I switched from the single wire 02 sensors to the 4 wire heated sensors on my 93 z28. Around the same time my battery would die if I left my car off for too long. I was just wondering if converting to the heated sensors could be causing this. The link below is how I set mine up.
http://www.fastbird93.com/Installati...Conversion.htm
Old Oct 18, 2009 | 06:36 PM
If you used "switched" 12V power, as shown in the wiring diagram, there's no way the heater circuit can drain the battery when the ignition is off.
Old Oct 18, 2009 | 06:37 PM
bobdec's Avatar
Make sure the switched +12V source is +12 Ignition NOT +12V BAT. Power to heaters should only be on when the key is on. If that's OK then you have another problem, the O2's will not draw any current with ignition off.
Old Oct 18, 2009 | 09:41 PM
TM2S3's Avatar
I'll check that out. Thanks
Old Oct 24, 2009 | 06:37 PM
TM2S3's Avatar
I had my sensors tied into the +12v battery. Everything should be good now.
Thanks for the help
HectorM52
Jul 30, 2017 11:46 AM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
Sandersen511
Jan 13, 2015 03:49 PM
XtremeLt1
Sep 13, 2002 08:50 PM
