dual voice coil sub question
Old Oct 10, 2009 | 03:42 PM
pearlpurple's Avatar
I have a 10 inch dual voice coil Fosgate sub.
What is the best way to run it??
Run my amp in mono and use one voice coil or run my amp in stereo and use both voice coils???
Thanks.
Old Oct 10, 2009 | 05:54 PM
The Untouchable's Avatar
u cant just use one voice coil u will ruin the sub , run the amp briged and wire the two voice coils parellel , that will make your amp run 2 ohms and put out the most power
Old Oct 11, 2009 | 07:53 PM
96 Z 28's Avatar
Just make sure they are 4 ohm coils, if they are 2 ohm coils then you'll have a 1 ohm rating, and you'll need to make sure your amp is 1 ohm stable.
If they are 2 ohm coils and your amp is only 2 ohm stable then run each coil as a separate channel.
Basically you'll need to know the ohm rating on the coils and how low the amp can still be stable.
Wiring Models
Old Oct 14, 2009 | 03:32 PM
Wiring Models
Thanks guys.
Amp is 2 ohms
Sub is 4 ohm voice coils
DougJ
Aug 29, 2002 12:51 AM
regular Joe
Aug 10, 2002 07:15 PM
regular Joe
Aug 8, 2002 03:47 PM
86IrocCamaro
Jul 22, 2002 09:44 AM
86IrocCamaro
Jul 22, 2002 05:57 AM
