88 MAF 2.8 work with 85 2.8?
Old Jan 20, 2003 | 10:39 PM
Polo-94Z28's Avatar
Question 88 MAF 2.8 work with 85 2.8?
I need a new MAF sensor for a 2.8L FI v6 camaro I bought, will an 88 MAF from a 2.8L suffice?
Thanks...
Old Jan 21, 2003 | 11:34 AM
oil pan 4's Avatar
yes
the sencors should be the same take the old one in just to be sure. If they look a like then they are the same.
Old Jan 21, 2003 | 02:23 PM
CODY BEHNKE's Avatar
On most MAF's the part number or calibration is molded in check to see if there the same.
Old Jan 21, 2003 | 11:31 PM
I EAT T/A's Avatar
I would think they are compatible, but the only way to check would be to call a dealer or NAPA.
Old Jan 21, 2003 | 11:56 PM
Polo-94Z28's Avatar
Seth - (oil pan 4)
In your sig, it says you need a 2.8L engine? Or am I wrong, because I will be taking this one out once I get it running really solid. Will use it to pass smog before I drop the v8 in.
Laterz
Old Jan 23, 2003 | 12:40 AM
oil pan 4's Avatar
1991 2.8L
The 88 2.8 I had in there is dead. I broke the 5 conecting rod off at the bigend and I now I have a 91 s-truck 2.8 engine to go in it.
I had just picked it up be for I left, it won't go in untill next summer or fall.
There isn't any point in doing it any time soon because I am on my way to japan.
Dec 1, 2016 05:37 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
67 Camaro
Sep 14, 2002 01:00 PM
