Will an EVAC system effect o2 sensor readings?
Old Aug 30, 2009 | 12:53 AM
walt355's Avatar
Where is the best place to place them?
Old Aug 30, 2009 | 09:05 AM
Do you mean a crankcase evacuation system driven by connecting a line from the crankcase, perpendicular to a high velocity section of the headers (eduction system)? If so, it going to pull air/vapor out of the crankcase, into the system, and if the O2 sensor is after the connection, its going to screw up the sensor readings.
Old Aug 30, 2009 | 02:58 PM
walt355's Avatar
So basicly if it is behind the o2 it should be Ok?
Old Aug 31, 2009 | 05:29 AM
The exhaust gas has to be moving fast to create a vacuum in the evacuation line. The farther away you are from the engine, the slower the exhaust gas moves, because its cooling down. You should keep the connection at least a foot past the O2 sensor, so backwash at low RPM does not affect the sensor.
Old Aug 31, 2009 | 06:41 AM
walt355's Avatar
sounds good, Thanks
Dec 1, 2016 05:37 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
