Looking for a good "rock" sub
Old Aug 25, 2002 | 10:53 PM
nSSane's Avatar
Post Looking for a good "rock" sub
My intent is to add a 10in sub to the factory system. What is a good sub for mostly "rock" music and which amp would you put with it?
Also, could you give a brief reason what makes it good for "rock" and why you choose it.
Thanks for the opinions
Bill
Old Aug 26, 2002 | 05:19 AM
firebirdude's Avatar
It's not really the sub that will matter the most. It's the install and the type of box you have. For mostly rock, I would go with a sealed enclosure. Do you have t-tops? Do you plan on keeping what little trunk space we have? I ask because MTX (and several other companies) makes a sealed box that fits right into the left hatch area. It utilizes room that normally would not be used. For just one 10".... I would go with that. Post back with your option and I will help you some more.
Old Aug 26, 2002 | 06:04 AM
LS1 RULZ's Avatar
I'm using a JL Audio Vantage Stealthbox with an Alpine Type-S subwoofer. I was using a JL Audio 10W3 but the Alpine blows away the JL. The JL is an excellent sub but the Alpine seems to be a MUCH better match for the .6 cubic feet of the Vantage enclosure.
http://images.cardomain.com/installs...32_89_full.jpg
As for an amp...Look into a class D subwoofer amp. I'm using an MTX Thunder 6500D. The amp pumps out 600W into the Alpine's 2ohm load. I only listen to ROCK (no cRAP, hip-hop, or any of that other BS) and it sounds GREAT!!!
marineengineer
Feb 9, 2015 03:59 AM
mackirockz
Feb 4, 2015 07:03 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
skittlez87
Dec 29, 2014 03:24 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
