pushrods
Old Jan 13, 2003 | 08:29 PM
99huggerorangeZ's Avatar
Question pushrods
i have heard that when you use a roller cam you need -.100 shorter pushrods so that the rocker tip will line up in the right spot on the valve
is this true or can i just use stock lenght pushrods
Old Jan 13, 2003 | 08:50 PM
Mindgame's Avatar
Re: pushrods
Well it depends...
If it's a retro-fit hydraulic roller you probably need a pushrod that's about .500" shorter than standard length for a flat tappet cam setup. Reduced base circle cams also need a different length. The "right" length is something that depends on quite a few variables. So, the best thing to do is to buy an adjustable pushrod (used for setting length), mock everything up and adjust it until you get 'center-travel' across the valve stem. When you get it right, check the length of the adjustable pushrod and order pushrods that length.
Comp has details on their website describing this procedure.
-Mindgame
Old Jan 17, 2003 | 01:52 AM
no i am using the oem stock rollers
so if i am going to be using that setup should i just find out how long the oem pushrod is and go with that size?
Old Jan 17, 2003 | 10:25 AM
"stock rollers"..... stock for what engine, year, etc.???
You aren't getting much in the way of responses because no one knows what engine you are talking about. These questions belong on the correct "Gen" forum.....
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
