Don't be afraid to change your plugs!!
Old Jan 12, 2003 | 09:42 PM
dkeers's Avatar
From what I read about changing plugs, it sounds like a nearly impossible job. I was sure I was going to get half way through and not be able to finish. I belived all of the hype mostly because I had never actually been able to see the #8 plug wire let alone the plug.
I did it this afternoon and it is a piece of cake. I took my time but I could have easily been done in just over an hour (I had a whole afternnon to kill ). The only thing that needs moved is the air tubes and that is only four bolts. The #8 plug came out of the bottom after about 10 minutes or less.
What I am saying is before you assume it is too hard and shell out $80 or more, try it. I actually had a good time (I love working on my car).
Dustin
Old Jan 12, 2003 | 09:45 PM
stik6shift98's Avatar
ya im 17 and if i could do it u can........ actually i think i was 16 when i did it......
Highlander
Jan 12, 2020 02:13 PM
Dec 1, 2016 05:37 PM
David Dorris
Jan 17, 2015 08:10 PM
