i need plz quick
Old Apr 24, 2009 | 06:50 PM
1994v6cam's Avatar
Exclamation i need plz quick
i have a 1994 camaro 3.4l v6 i just replaced the engine in it and dash and went to crank it it didnt crank??? all the wire are conected at the end of the dash but under neath there is a gree and yellow wire that have a blue end. also im not getting any power to the fuse but the ignition will make a noise like it sapose to. can you tell me where that yellow and green wires go and or show a wiring harness online thenx
Old Apr 24, 2009 | 07:14 PM
mdacton's Avatar
be more clear about what you are describing.
Do you have any way to take a picture of the plug?
Old Apr 24, 2009 | 08:33 PM
1994v6cam's Avatar
srry
i have a pic
http://s224.photobucket.com/albums/d...rent=mycar.jpg
see i dont no where it goes. also my gauges arent getting no power along with the fuses
Old Apr 25, 2009 | 06:51 AM
Do you mean the starter will not activate or engage, or the starter turns the engine, but the engine will not start?
You should have been able to replace the engine simply by unplugging the engine harness connectors. Why did you have to work on the wires in the (fuse panel??) at the end of the dash? And the wire you are asking about is "underneath" what?
You are not getting any power to which fuse?
What part of the ignition is making what kind of noise like it is supposed to?
Old Apr 25, 2009 | 02:23 PM
1994v6cam's Avatar
i changed it from a 5speed to an auto. and i changed the starter and it still wont ingage to turn the motor like the starter wont move. but i still dont know where the two wires go can u help. also none of the fuse are getting power
Old Apr 25, 2009 | 02:38 PM
If you have no power to any fuses, and nothing happens when you turn the key to the start position, you have to start at the battery. Did you check the battery? Did you check the red battery wire/terminal for corrosion? How good is the ground wire? Have you checked the various fusible links? Did you check to make sure you attached the 12V wire to the starter?
Was the wire you are asking about always hanging loose, or did you remove it while you were doing the A4 -> M5 swap?
Old Apr 25, 2009 | 04:57 PM
1994v6cam's Avatar
i think it might be the wires im bying a new battery and the wire was hanging out underneath the driver side of the dash when i swaped
Old Apr 25, 2009 | 06:51 PM
mdacton's Avatar
did you change the pedals as well?
It isn't the wire for the nutral safety switch is it? went to a sensor on the clutch pedal....
Old Apr 25, 2009 | 08:40 PM
1994v6cam's Avatar
no b/c its on the other wireingn harness 2. i think there might be a ground out there is no power to gauges, fuse, or windsheild wipers. but the head lights come on but no turn signials thanxs
Old Apr 26, 2009 | 08:32 AM
1994v6cam's Avatar
i changed the pettals and i cant find where it goes
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
colts0455
Sep 11, 2015 06:16 PM
