3000 stall
Old Apr 21, 2009 | 07:47 PM
mikemassi's Avatar
3000 stall
i have a 94 z28(A4) slightly modded, just bolt ons and exhaust. and im getting a trans rebuild, and i have a 3000 stall sitting around. think that is too high of a stall for a stock cam?
Old Apr 21, 2009 | 09:07 PM
mikemassi's Avatar
stock cam
ok i tried this in drivetrain but no responses. im getting my trans rebuilt with all heavy duty stuff and corvette servos and shift kit. i also have a 3000 stall im getting really cheap. with the stock cam in a 94 z28(full bolt ons/full exhust) would this stall speed be fine? and still be able to be a frequent driver?
Old Apr 21, 2009 | 09:20 PM
Z28Freak86's Avatar
Ultimately, stalls and cams dont matter too much, but a stall really has a good effect with gear ratios. If you were to change out ur gears in the rear to anything like a 3.73 or 4.10, a higher stall would really open it up more. With the stock drivetrain (im assuming u dont have a 2.73 gear) then a 3000 stall would be ok. Read the sticky on stalls in Drivetrain if u want to learn more (very good sticky)
Old Apr 21, 2009 | 09:44 PM
n2ceptor's Avatar
Torque converters and cams should match as with other components, depending on application...
General information here, plus you could google other sources.....
http://www.summitracing.com/streetan...BD43F224310%7D
Old Apr 21, 2009 | 10:10 PM
LearJet's Avatar
not at all, try it, you'll like it.
Old Apr 21, 2009 | 11:47 PM
93FIRETURD's Avatar
As anyone will tell you the cam and converter should match up however i had a 3000 stall on my stock cam car and can tell you it was a blast to drive, when it was loud i would run through town at 35 and slap the gas, the converter would stall out very quickly and scare the **** out of people ha ha thats always a good time, it also really helped with my launches and if you plan on putting a cam in eventually the converter is already there i say go for it.
Old Apr 22, 2009 | 07:19 AM
rskrause's Avatar
It's a personal preference but if you have it, why not try it?
Rich
Old Apr 22, 2009 | 02:01 PM
FirstYrLS1Z's Avatar
do it,and after a while you'll want a bigger stall.
Old Apr 22, 2009 | 05:11 PM
camaro81's Avatar
I went with a 3000 stall when my car was bone stock it was the best mod I ever did to the car, made it so much more fun to drive.
Old Apr 22, 2009 | 10:33 PM
mikemassi's Avatar
do u know if it was a 10" or 12" converter? and how was it driving wise? could it be a daily driver?
Old Apr 22, 2009 | 10:35 PM
mikemassi's Avatar
was it able to be a daily driver? and was it a 10 or 12" converter
Old Apr 23, 2009 | 12:04 AM
You got several very good responses on the Drivetrain forum.
https://www.camaroz28.com/forums/sho...d.php?t=682583
Merging
Old Apr 23, 2009 | 12:56 AM
93FIRETURD's Avatar
i drive it daily for sure the car has 154xxx miles on it and counting, it is a 12 inch converter, be sure to get a converter with lockup, if you do not do so your car will cruise around at stall rpms while highway driving. this of course will result in terrible gas mileage.
Old Apr 23, 2009 | 04:55 AM
camaro81's Avatar
It isn't a daily driver, but I put more miles on the camaro than I do on my daily driver because I sometimes drive up to 300 miles to get to a track. The converter didn't hurt the drivability at all, it just made it a lot more fun to drive. The gas mileage was effected though
It was a 9.5" converter.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
