how did you connect to your side terminal battery??
Old Jul 21, 2002 | 08:27 PM
redz_02's Avatar
Question how did you connect to your side terminal battery??
Well usualy i would just get an o connector and then bolt it down, but my current system is using a 2 guage from the batterie to a 140 amp breaker. I plan on doing the same to the ground to eqaul it out to the frame. For big amp installs, what did you do.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Jul 22, 2002 | 06:25 AM
LS1 RULZ's Avatar
I used a sidepost terminal adapter and large gauge crimp-on ring connectors.
Old Jul 22, 2002 | 09:26 AM
DrMilhouse's Avatar
I'm guessing that if you're running 2 guage, your system is probably big enough that you're going to want a bigger battery to begin with. In that case, I'd recommend what I did which is just get a red top optima and use the top posts for your stereo and the side posts for the rest of your car.
HTH
99 Z28 LS1 (broken with 383 replacement in the works) M6
stereo pics FOR SALE!!!
Moderator at CamaroVsMustang.com
Send while you can!
Old Jul 24, 2002 | 09:42 AM
rthompson's Avatar
<font face="Verdana, Arial" size="2">Originally posted by DrMilhouse:
HTH
</font>
Why red top? Optima suggests the Yellow top for use in car stereo, and using a Red top in audio applications voids the warranty on it... read the FAQ on the optima site, it is very informative.
Soundillusions.net
The ultimate in caraudio.
Sony, Arc Audio, Infinity, Adire Audio, A/D/S
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
nosliw
Feb 7, 2015 01:30 PM
PaulN64
Aug 8, 2002 05:39 AM
Omega9
Aug 2, 2002 12:33 AM
