Mufflex?
Old Apr 7, 2009 | 03:38 PM
mightymouse383's Avatar
Mufflex?
Thinking of going with a mufflex system any suggestions?
Old Apr 8, 2009 | 10:21 AM
mzgp5x's Avatar
I did a Mufflex. (App... 97ss 383ci D1 Procharg MM6 trans+ Moser) 3 1/2" single cat back Spintech muffler single pipe dump on the left. The Spintech is a chambered muffler, and, you may want to go with another option depending on your application.
The cat back pipe did not fit my Random Y well (stock pipe is longer & OK). I fabbed a transition joint. Also, I had some trouble with their band clamps. The pipes came loose and apart under high boost (PITA). I fixed that with 3/8 threaded rod and 1/2" steel hydraulic tube (welded).
The Mufflex does have a nice kick over the axle with no area restriction. It does get close to the pan-hard bar. Tight with the 3 1/2" system.
Also, the exit tube hanger was quite wimpy. Bent under heat and road jounce loading. Fixed that also.
Now, I have modified it alot including a QTP dump. But, it's OK for a start. For FI go with the 4". Not much room under an F_body for exhaust system with ground clearance.
HTH. B.
Old Apr 8, 2009 | 10:23 AM
9T8W66's Avatar
I have the 3.5" Single on the left system with the Flowmaster 30 series Race Muffler.
It has a much deeper tone then my old 3" SOTL setup.
Installation was pretty straight forward but required a little fabrication work to eliminate all rattles esp. the over the axle pipe.
Heres a couple pics taken directly after install.
System has since been modified and tucked up even more.
Old Apr 9, 2009 | 10:06 AM
That setup is sweet, i like it!!!! How much is it and where do i get it?
Old Apr 10, 2009 | 10:04 AM
9T8W66's Avatar
I won't post a link on here for a non sponsor and you don't have your Private Messaging setup so check your profile.
Old Apr 10, 2009 | 10:05 PM
If someone asks about a specific product, you can post a link, as long as you do not have a financial or other interest in that business. That's not advertising, that's helping someone out.
I ran the 4" Mufflex catback for a while.... very tight fit over the axle. Actually wedged in against the chassis with no clearance. It was installed by Mufflex, behind a custom Y-pipe with dual CarSound cats. Great setup for a higher HP application. A buddy of mine used the Mufflex 4" on his 9.04-second 30th SS convertible. We both eventually removed the system to save weight, with no apprecialbe gain in HP, so its a pretty free flowing system with the Flowmaster.
http://www.mufflex-performance.com/
Old Apr 11, 2009 | 06:54 AM
9T8W66's Avatar
Thanks Fred
Old Apr 11, 2009 | 07:47 AM
I think i will go with one of there systems, i went to the web site and liked the setups they offer. Thanks for all the help guys.
Nick
G-BODYT56
Jan 14, 2022 11:14 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
onebad96T/A
West South Central
Nov 14, 2002 10:36 PM
CAJUN-Z
Sep 19, 2002 03:21 PM
