DataMaster/Tuner Cat questions.
Old Mar 21, 2009 | 08:40 PM
BMD18's Avatar
Yes im sorry for being crappy to others on here that are trying to help me. I just get pissed when people get snot nosed. I really need help though i will be getting 3.73's soon and i just need to know how to tune my speed O and Tac to compensate for the 3.73's. How do i do this????
Thank you Brian
Old Mar 21, 2009 | 10:57 PM
shoebox's Avatar
Tunercat has a built in speed calibration converter. Have you looked at the program? These questions are usually posted in the computer/diagnostics forum. There may already be answers you can search there.
A moderator will probably end up moving this for you.
Old Mar 22, 2009 | 09:29 AM
Thank you Brian
Whoaaaa.... no one got "snot nosed" with you. They questioned why you were using octane boost (which may have contributed to the problem you were having), and asked you to clarify what you meant when you said you were revving your engine to "5, 6, 7" (another completely valid request). Both of those were legitimate questions, and you went off the deep end with your attitude.
Now you're extending your argument into another thread. Get rid of the attitude, or no one is going to want to help you. I know I won't.
Old Mar 22, 2009 | 10:21 AM
That Camaro Guy's Avatar
Tuner Cat has a built in tool to help you adjust your speedo for new gears. It's under the "tools" tab called "speed calibration". Just enter your tire size IE 273/35/18 and your new gear ratio and click "calculate" then "apply". Your tachometer will not need any adjustment for new gears. With the stock 2.73s your torque converter will lock up around 45mph, with 3.73s and the computer fixed through Tuner Cat for the new gears it will now lock up around 33mph. The speedo adjustment will fix your speedometer to read accurate and adjust your shift tables accordingly.
If someone is asking you questions, they're probably just trying to make sure that they're helping you solve the correct problem and make sure you don't have another one you may be unaware of.
Old Mar 25, 2009 | 08:59 AM
JWS6's Avatar
With TC could make a help file for the 96-97 VDF!!!!!!!!!!!!!They say its in the works......
Old May 4, 2009 | 06:36 PM
BMD18's Avatar
[I have in immature potty mouth, so they had to edit this post]
Old May 5, 2009 | 01:29 AM
MikeGyver's Avatar
Yes im sorry for being crappy to others on here that are trying to help me. ... Thank you Brian
lmao! well I guess Injuneer was right... Sigh...
Old May 5, 2009 | 05:01 AM
BMD18 is no longer with us. I guess they pulled the plug on the PC at the day care center......
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
