Wideband a/f question
Old Oct 8, 2008 | 05:59 PM
diarmadhi's Avatar
So one of the first things im going to do is get a wide band a/f guage in this sucker..
My question is where would be the optimal place for the sensor.. I am assuming as far down the headers as possible but before the cats?
I would share my list of things.. but my car is going to surprise quite a few after i get it... I am thinking outside the box.
Old Oct 8, 2008 | 07:38 PM
Grape Ape's Avatar
Unless it is heated, you want it as far forward as possible because they don’t work until they warm up. And if you are planning for nitrus, this will help the ECM adjust a hair faster.
Old Oct 8, 2008 | 10:35 PM
diarmadhi's Avatar
Hrm.. gonna have to dig for more research info then...
And no not going to spray.
Old Oct 9, 2008 | 10:23 AM
jay_lt4's Avatar
cool, someone else with big plans right away, i like it!
Old Oct 13, 2008 | 10:31 PM
Highlander's Avatar
Who says the PCM will adjust itself??? so far, adding a WB sensor will not make the PCM adjust itself for WOT conditions.
Old Jan 17, 2009 | 10:03 PM
The typical wide-band sensor/contoller is fully heated and compensated for temperature, allowing it to be placed remote from the heat of the engine. Obviously it has to be before the cat, but exact location is not critical.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
