stock fuel gauge bouncing around...?
Old Jun 23, 2008 | 09:42 PM
6Speed's Avatar
My car has been in storage for a few years now...only cranked up here and there. The other day when I pulled it out of storage the gas gauge bounced up to full and then back down to 1/4 tank. After a few minutes of idling it went all the way as far to the right as it could go and stayed there. The car runs fine otherwise. The tank is not full. Is my fuel pump about to give up the ghost?
Old Jun 23, 2008 | 09:55 PM
lt1stroker's Avatar
I had this same question a while back. People have told me that GM factory gauges are a little weird. For ex., when it says a 1/2 tank, its really a quarter and so on.
Old Jun 23, 2008 | 11:09 PM
While the calibration of the stock gauge is "off", that wouldn't explain the gauge moving suddenly from 1/4 to full and back. Sounds like a bad connection on the wire from the level sender to the gauge, or the sender itself. A full right indication generally reuslts from an open circuit.
Old Jun 24, 2008 | 07:35 PM
gnomee's Avatar
Yes this is most likely an issue with the sending unit in the tank.
I had a similar issue when I took a long road trip and it turned out to just be nasty gas causing it. After a 2 fill ups locally at QT and the gauge started working right and has not had any other issues.
If you are not as lucky as me you will be needing a new sending unit which means dropping the gas tank.
Good Luck!
Garcia5
Jul 7, 2022 06:51 PM
Red Hawk 94
Mar 18, 2019 04:03 PM
jj71787
Jan 31, 2015 10:20 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Catmaigne
Dec 25, 2014 12:16 PM
