I need help identifying this...
Old May 1, 2008 | 09:12 PM
Red93Camaro's Avatar
The Blinker thing on the left of your steering wheel/ cruise control / wiper fluid etc...idk what its called...BUT those all work except The windshield wiper part, I twist it towards me and every speed doesnt work but the HI speed... Is there some kind of little computer in there I need? or something? What do I need fixed, cause I need that ASAP
Thanks for the help!
Old May 1, 2008 | 09:30 PM
TheZ_project's Avatar
It is probably the wiper motor not the combination switch/multi switch. Check the wiper motor connector to see if power is being supplied to the low speed side when you have the switch set to low speed.
Old May 1, 2008 | 09:45 PM
Its shot the previous owner said ...so Its the whole motor itself?
Old May 2, 2008 | 12:27 PM
So all I need is a new windshield wiper motor? to get all the speeds? or something else.
Old May 2, 2008 | 01:59 PM
ss.slp.ls1's Avatar
When you turn the twist it, but not all the way to high speed, do the wipers lift up an inch and stay there, and then go back down when you twist it back off?
Old May 2, 2008 | 04:29 PM
shoebox's Avatar
It could be the switch inside the column, too.
Old May 2, 2008 | 05:26 PM
no they dont move at all...They only move on the Hi speed...and they make a weird clicking noise I think the wipers are loose.
cjamen
Jul 27, 2015 12:48 PM
Latronaxe
Jun 10, 2015 02:08 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
R_Andersen
Jun 9, 2003 12:14 PM
Jeff H
Classic Engine Tech
Dec 1, 2002 02:35 PM
