stroker
Old Apr 30, 2008 | 11:15 AM
Bails098's Avatar
stroker
383 stroker low compression for nitrous, edelbrock ported heads, intake and 58mm throttle body, 1.6.1 rockers msd ignition/coil i foreget the cam numbers. I am looking for a stand alone system any suggestions on some and also any input on megasquirt.
Old Apr 30, 2008 | 03:09 PM
Why would you run "low compression for nitrous"..... nitrous loves high CR.
From the 58mm throttle body, we can assume its an LT1... why not add a "signature" with basic info about the car - year, model, engine, tranny and any major mods.
The megasquirt is generally covered on the "Computer....." forum. I can move it there if you like.
Old Apr 30, 2008 | 05:24 PM
rskrause's Avatar
What do you think you will gain with a stand alone? Unless you are planning a 500hp multistage system, don't lower the CR for nitrous.
Rich
Old Apr 30, 2008 | 05:58 PM
Generally not a good idea to post the same thread in two forums. Since you already have this on the "Computer...." forum, we'll close this one.
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
Cbr02
Aug 23, 2015 10:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
