One reverse light not working....?
Old Apr 27, 2008 | 08:22 PM
KillinFormula's Avatar
my pasenger reverse light in not coming on, i have changed the bulbs, and nothting, so i did a voltmeter test and i there is no voltage. But the driverside light works fine... any ideas. I read up on the B/U light switch on the tranny, but would that cause just one to go bad or both?
Old Apr 28, 2008 | 07:53 AM
2000GTP's Avatar
You could have a bad socket connector. Probe the harness a little further down and see if you are getting voltage. If you are getting voltage at the actual wire but not at the connector, then you found the problem. Also make sure that the contacts are clean as well.
Old Apr 28, 2008 | 11:10 AM
i checked down on the wires and still no voltage...... so i think it is more than a bad socket connector
Old Apr 28, 2008 | 01:15 PM
Please don't post anything but "engine" questions on LT1/LT4 Engine Tech.
Moving.........
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
kizz
Aug 28, 2002 09:39 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
