gas cap code
Old Apr 18, 2008 | 12:19 PM
TJ Chapman's Avatar
gas cap code
check engine light came on about a day after getting gas for the first time. i just figured it was a code the previous owner erased to sell the car. and i went to autozone (i know autozone) to get the code read and he said it was a gas cap. mine had a dried up cracked seal so i bought a new one and the SES light is still on do i have to get that erased or will it go away in a few ignition on cycles?
Old Apr 18, 2008 | 12:32 PM
2001NBMZ28's Avatar
P0440? Should turn off by itself after 3 consecutive ignition cycles the diagnostic runs without seeing a failure, stays in "history" for 40 cycles after light turns off.
Old Apr 18, 2008 | 02:45 PM
Marc 85Z28's Avatar
Clear the code with a scanner, disconnect the battery for several minutes, remove the PCM memory fuse for several minutes, or wait numerous drive cycles.
And only late model Fords have a true gas cap code. P0440 on GMs is a generic evaporative emissions system fault, and could be many things, gas cap included.
Old Apr 20, 2008 | 08:38 PM
TJ Chapman's Avatar
what could all be responsible for P0440?
Old Apr 21, 2008 | 09:50 AM
Marc 85Z28's Avatar
Gas cap, fuel filler neck, gas tank, fuel pump wiring harness, fuel pump seal, numerous hoses, EVAP canister, EVAP canister vent valve, EVAP canister purge valve, PCM, wiring, etc etc.
Old Apr 22, 2008 | 11:04 PM
TJ Chapman's Avatar
yeah makes sense. the light still isnt off after about 4 days with the new gas cap, i just have to get a modis hooked to it and clear it and go from there i spose
Old Apr 23, 2008 | 06:19 PM
Marc 85Z28's Avatar
Surely you didn't buy one of those WAAAY overpriced heaps...
Old Apr 24, 2008 | 12:01 AM
TJ Chapman's Avatar
nope our shop owns one i have no reason to buy one lol i could buy almost a whole nother Z for the price of one of those
blac94Z
Nov 24, 2014 07:12 PM
DW96Z
Aug 31, 2002 09:46 PM
simple
Aug 11, 2002 11:56 AM
91Bird305
Aug 5, 2002 01:39 PM
