5.3 V8 DI 400HP as the BASE V8
Old Apr 18, 2008 | 11:23 AM
2001Firehawk's Avatar
Got to thinking about Scott saying that we're in for some big surprises.
The biggest surprise I believe, will be what the BASE V8 will be.
From the get-go, I believed that the Camaro, was going to be the showcase vehicle, for the next generation of V8 engines.
The design goal will probaby be a BASE V8 with 100HP more, than the BASE V6.
With a 2.0L 260HP I4 , & a 3.6L 304HP V6 already done.
The time for the DI V8 is here now.
With everyone knowing that it won't be the LS2 , & thinking that it will be the LS3, I think that we'll be in for a nice surprise...
Old Apr 18, 2008 | 11:28 AM
skorpion317's Avatar
Nope.
The LNF 2.0L turbo DI engine was mentioned in passing by Bob Lutz as a possibility if CAFE causes a problem for the Camaro. It's not even remotely close to "already done".
The LS3 will be the "base" V8. The Gen V DI motors aren't quite yet ready to be released.
Old Apr 18, 2008 | 11:33 AM
SManZ's Avatar
I don't know much about the 5.3 motor...what would its advantages be? Is it DOD capable? DI would provide better mileage - do you expect mileage figures to be better than with LS3?
Just curious and want to learn more
Old Apr 18, 2008 | 11:38 AM
Unless GM is developing a new RWD 5.3L V8, the only 5.3L V8s in the lineup right now are the Vortec truck engines. They put out between 315-320 HP and 340 lb.ft. of torque.
Old Apr 18, 2008 | 11:42 AM
CLEAN's Avatar
He could be talking about the LS4, which I have in the Impala, but as far as I know, it's a FWD only engine. Besides, the DI 3.6 makes more power (though mine sounds better ), so why would you want an LS4? A 400hp 5.3 would be fun, but I suspect that's not what it's going to be.
Old Apr 18, 2008 | 12:25 PM
HAZ-Matt's Avatar
Gen Vs will either debut in a Cadillac truck or the Corvette.
Old Apr 18, 2008 | 12:28 PM
FiefSS's Avatar
That would be cool.. probably won't happen out of the gate. But I'd have no problem driving a 400hp 5.3l Camaro if it got a few more mpg's...
Old Apr 18, 2008 | 02:15 PM
Primus's Avatar
Nope.
When he said, "already done", I think he was referring to the motor being already done on other GM cars.
Old Apr 18, 2008 | 02:23 PM
The LS4 is a FWD only engine. If it were put into a RWD application, the throttle body would be facing the firewall.
Old Apr 18, 2008 | 02:32 PM
CLEAN's Avatar
I know, that's why I said as far as I know, it was a FWD engine only.
Old Apr 18, 2008 | 02:50 PM
It would be possible to put the LS4 into a RWD application if a new intake manifold were made.
However, I don't think there's any point to putting the LS4 into the Camaro.
Old Apr 18, 2008 | 04:35 PM
TrickStang37's Avatar
Nope.
you have zero credible sources.
Old Apr 18, 2008 | 05:11 PM
Mjolnir's Avatar
The LS4 has the horsepower, but does it have the torque to move a Camaro?
You're looking at ~1000 pounds difference.
Old Apr 18, 2008 | 05:44 PM
Grape Ape's Avatar
Which would be ideal for a functional cowl induction hood
Old Apr 18, 2008 | 07:50 PM
CLEAN's Avatar
323lb/ft for the LS4, 276lb/ft for the 3.6 DI V6.
