Which H20 pump, CSR or Meziere?
Old Apr 6, 2008 | 03:13 AM
RUNMYTA's Avatar
Which pump do you prefer for higher HP boosted applications? I read somewhere that the Meziere flows a little more than the CSR, but the CSR is less expensive. Thanks!
Old Apr 6, 2008 | 05:29 AM
OneFlyn95z28's Avatar
Not boosted right now but I have an old CSI(CSR) on its 6-7th year.
I can pull the trigger out of the hole and make a full pass. By the time I get back to the pits she is at 180*.
On the street it never gets over 180* even in hot weather.
Here are a few things to consider with this info.
Block is rocked to the plugs
BeCool Radiator
250RWhp shot out of the hole...yes all at once.
180* by the time I get to the pits
Old Apr 6, 2008 | 10:05 AM
97WS6Pilot's Avatar
I went through 2 stock pumps in five years when I first bought my car in 96. I've had the current Meziere HD Pump in since 2002 with no problems. I put alot of miles on my car since it is a daily driver. My supercharged car gets hot when it is over 90 degrees outside and I idle for longer than 10 minutes with the AC on. If I turn the AC off it will go back to normal temperatures. Never tried the CSI but any electric is a big improvement over the stock pump.
Old Apr 6, 2008 | 10:54 AM
RUNMYTA's Avatar
Is there any major issues with running the Meziere HD over the standard as far as install.
Old Apr 6, 2008 | 01:00 PM
97s10ondubs's Avatar
The CSR doesnt flow as well, but it's also smaller, more room, no clearance problems with the stock fans if you still have them. I have the CSR
Old Apr 6, 2008 | 09:18 PM
97WS6Pilot's Avatar
You have to trim your fan shroud a little. You also have to install a freeze plug in the back of the waterpump housing. I went with a cloyes true roller for better valve timing and price at the same time. I also plugged the timing cover hole with a freeze plug and some JB weld.
I have not had to replace the Meziere yet but it will be a breeze to replace if it ever goes bad. It just pulls right out of the front of the waterpump housing.
When you install the Meziere make sure you buy a painless wiring harness and solder and shrink wrap all the wires to protect them from the weather.
Old Apr 7, 2008 | 12:54 AM
RUNMYTA's Avatar
So is the Meziere HD the better choice over the standard Meziere. I am looking to make 600+/- RWHP and keep the car on the street more than the track. So cooling is a must. Which is the better choice for mostly street use?
Old Apr 7, 2008 | 05:04 PM
cjmatt's Avatar
i love my csr, just make sure the hex bolts are tight, one of mine backed out and the pump stopped flowing
Old Apr 7, 2008 | 06:03 PM
97WS6Pilot's Avatar
It doesn't matter which one you use. They are all good. The wiring you install is more important than who makes the pump. I know Jegs and Summit both sell electric pumps. Like I said I have had good luck with the Meziere HD but it is kind of pricey.
Old Apr 7, 2008 | 06:08 PM
We just replaced a CSI pump in a customers car. it had 65K miles on it and had been driven in rush hour traffic every day since 02
Mar 13, 2016 03:39 PM
Mar 15, 2015 07:01 PM
BMX Dad
Jan 23, 2015 07:00 PM
Zone
Jul 29, 2002 07:43 PM
TAChad
Jun 14, 2002 03:44 PM
