Bottom End Q's
Old Mar 31, 2008 | 12:35 PM
SSandman's Avatar
Bottom End Q's
I guess this could have went in the F/I section but it is really specific to the bottom end and I figured there would be some technical debate so it may belong here?
First off, how do you splay main caps on a motor if it already has 4 bolt mains? Im guessing material would be welded into the old bolt holes so the new holes can be drilled? Is this going to compromise the strength of the block over starting with a fresh 2 bolt main block?
What do all of you guys think about deck O ringing? I find so many mixed opinions on this when searching it is not even funny. Is it needed/necessary on a motor putting out less than 15psi? I plan to try to achieve my power levels through a well breathing motor with relatively low boost (wont see over 15psi).
How about head studs instead of bolts? Another mixed bag of opinions although my gut instinct tells me that SBC's seal pretty well so I don't think i'd need studs with 15psi or less.
thanks
Old Mar 31, 2008 | 02:18 PM
Is this a stock 4-bolt LT1 block you are asking about?
Old Mar 31, 2008 | 04:09 PM
SSandman's Avatar
The block I have is a 4 bolt block, not originally (it's an LT1 block not LT4) but it was drilled out for std 4 bolt mains. NOT splayed however, but I wish to convert it to splayed due to the added stress on the mains from the blower.
Old Mar 31, 2008 | 04:52 PM
I buddy of mine started with a stock 4-bolt LT1 block. 383, Vortech S/C making over 20# of boost and 1,125HP. The stock 4-bolt configuration held up fine to that level of power.... upgraded caps and bolts of course. The shop that built the engine took some measurements before commiting to keeping the straight bolt configuration. They seemd to feel that GM had done their homework in designing the LT1 block, putting the extra metal right where it belonged for the straight 4-bolt configuration. Drew parallels to the design of the Bowtie block, in that respect. They seemed to feel that drilling splayed holes where GM didn't intend bolt holes to be located might actualy produce a weaker configuration than the stock straight bolt setup.
Just a thought.
Old Mar 31, 2008 | 05:50 PM
SSandman's Avatar
Wow, thanks. I'll have to talk with my machine work guy about this and see what we come up with. It'll save me some cash for sure if indeed I don't need or shouldn't have splayed caps.
Old Mar 31, 2008 | 06:11 PM
1racerdude's Avatar
Keep what you have as Fred said.
The extra machine work isn't worth it. There is an ongoing debate as to which is stronger.
The block will fail before the streight 4 bolts and caps.
Old Mar 31, 2008 | 08:02 PM
MachinistOne's Avatar
Keep the block as is, I assume that the 4 bolt conversion uses studs?
For the kind of boost that you are talking about, a stock gasket with head studs will hold just fine. If you want to be extra safe, I like the SCE Titan ICS copper gaskets - no need to be doing an o-ring install on most blocks these days with the quality gaskets that are available.
Old Mar 31, 2008 | 08:44 PM
rskrause's Avatar
I use straight 4-bolt billet caps.
Rich
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
sscott
Jan 17, 2015 04:30 PM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
