dual cat set up?
Old Mar 25, 2008 | 08:20 PM
TheZ_project's Avatar
dual cat set up?
I was looking under my car and on the left side up near the manifold there is a large cylindrical lump of steel that I am guessing is a cat. I also have a cat just ahead of the point where the 2 pipes converge into 1. Assuming the left one is a cat is there anything preventing me from just eliminating it. I want to get a set of pacesetter LT's and a cat back system. Are there and other differences in the y section of a dual and single cat set up? If someone could give me a definate answer that would be great because my mouse clicking finger is itching to hit some add to cart buttons online.
Old Mar 25, 2008 | 08:54 PM
2000GTP's Avatar
It sounds like you have a California emissions car which had the dual cat option on the automatic cars. If you are doing Pacesetter LTs, it is not going to matter if you have a single or dual cat y-pipe as the Pacesetter off-road y-pipe is what you are going to use to hook up to the headers. There is no way you will be able to reuse your existing stock y-pipe on long tube headers.
Old Mar 25, 2008 | 09:00 PM
So basically I put the headers on, add the y-pipe and a cat at the end of that, then the cat back system. I am guessing the ory will need to be cut a bit to fit the cat? I am planning to get a magnaflow cat but i havent decided on a cat back system yet. I like magnaflow products, i run a magnaflow system on my jeep. I will have to sse if they have a cat back system for my car. Thanks for the response 200GTP.
Old Mar 25, 2008 | 09:04 PM
2000GTP's Avatar
Yes, some people do run the cat at the end of the y-pipe and you would have to probably trim both that and the i-pipe portion of the catback to get it to fit. However, by running the cat there, it is pretty far back and will not heat up as well and be as efficient. If you have to pass tailpipe emissions, this may be an issue. Also, Magnaflow does make a nice stainless catback for the LT1 cars, I have the Magnaflow catback on my car along with the Pacesetter long tubes and y-pipe.
Old Mar 25, 2008 | 10:03 PM
caldercay's Avatar
I was looking under my car and on the left side up near the manifold there is a large cylindrical lump of steel that I am guessing is a cat. I also have a cat just ahead of the point where the 2 pipes converge into 1. Assuming the left one is a cat is there anything preventing me from just eliminating it. I want to get a set of pacesetter LT's and a cat back system. [snipped]
As confirmed by 2000gtp, this is most certainly the CA edition. Are
you in CA? Do you have the O2's behind the last cat? And are you
in an emissions state?
Old Mar 25, 2008 | 11:16 PM
The 95 "CA emissions" A4 cars have dual cats, but did not have after-cat O2 sensors.
Old Mar 26, 2008 | 04:24 AM
jasonface's Avatar
Relocating the cats may mean an automatic fail next time you go for emissions check. Of course, not all shops will catch it. I've had mine smogged twice, including once at a dreaded "test only" station, and neither time was it a problem that my cats were further back (due to the headers). Pretty much a crap shoot. Good luck!
Old Mar 26, 2008 | 07:46 PM
well i basically only need to have the cat for looks. NH is not a sniffer state but we do have to do visual inspections. I am a licensed inspector and generally dont bother people over cats unless they are being irritating but on my own car, if i write myself a sticker and get pulled over by the DOT officers I will automatically lose my inspection license of 30 dyas and get fined a min of $250. I checked my RPO's and it shows CA emissions package but the car is originally from VA. Also, does the magnaflow have much droning inside the car?
Old Mar 26, 2008 | 07:48 PM
2000GTP's Avatar
I have had absolutely none.
Old Mar 27, 2008 | 09:47 AM
.......... if i write myself a sticker and get pulled over by the DOT officers I will automatically lose my inspection license of 30 dyas and get fined a min of $250.......
You're lucky... in NJ it can be $10,000 fine, 6 months in jail, and permanent loss of license by the facility you are employed at. Violations are handled in a special "emissions" court, where they make it almost impossible to have a lawyer present.
Possession of a counterfeit sticker also carries MANDATORY jail time and a fine
The Gestapo is alive and well in NJ.
Old Mar 27, 2008 | 09:55 AM
6speedZ28's Avatar
Luckily Indiana pretty much doesn't do emissions unless you are up North in Lake County. How do you get your car to pass? Or is it a track car only?
Jan 23, 2015 01:13 PM
alphaauto
Jan 23, 2015 07:42 AM
alphaauto
Jan 22, 2015 08:02 PM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
