1995 Camaro Z28 Auto
Old Mar 23, 2008 | 03:27 PM
dirtydsm's Avatar
It has a small issue when we park the car without the e brake it rolls back (its auto) what could this be?
Old Mar 23, 2008 | 05:09 PM
shoebox's Avatar
Rolls back how much? All autos have a little slack when you put it in park.
Old Mar 23, 2008 | 06:10 PM
LSWHO's Avatar
All autos do it less than 6" or so.
Old Mar 23, 2008 | 07:07 PM
dirtydsm's Avatar
rolls back like a manual car without e brake its like in neutral.
Old Mar 23, 2008 | 07:16 PM
LSWHO's Avatar
Check the linkage (on the tranny and in the center console). Then if that doesn't work fix the broken tranny.
Old Mar 23, 2008 | 09:51 PM
12SCNDZ's Avatar
Try to disconnect your linkage, at the transmission. Move the transmission lever to the park position. See if the car tries to roll then. If your linkage doesn't line up with your cable, you may have a cable/shifter issue. Has the transmission ever been built? The bolts that retain the park linkage, in the transmission, could have backed out.
Frank
CPT
Old Mar 24, 2008 | 05:30 AM
dirtydsm's Avatar
Frank
CPT
completly stock car will do that
Old Mar 24, 2008 | 12:13 PM
LSWHO's Avatar
I had the same problem. Then my shifter stopped putting the car in drive correctly. Then I realized my shifter wasn't truly putting my car in park and that my linkage on the tranny somehow got loose. REAL loose.
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
Chrisdude
Jul 24, 2002 02:25 PM
Jake77444
Jul 21, 2002 05:37 PM
