3" Hooker -> 3.5" Mufflex
Old Mar 18, 2008 | 03:17 PM
user 647483's Avatar
3" Hooker -> 3.5" Mufflex (Spintech)
I love the sound of my current setup, but I picked up a 3.5"" mufflex at a good price last night.
I don't know if it's worth putting on my car or not.
Originally Posted by OldSchoolSS
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
So will upgrading from a 3" Hooker to a 3.5" Mufflex/Spintech help me at all?
Forged H/C 355, should make about 400-410rwhp @ 6300rpm N/A through a very loose 4000 stall. (2.65 STR)
(replaces my current 350, uses the same cam and heads but with more compression)
Already has LTs and the ORY could be modified to accept a 3.5" catback.
Complete mods list -> http://www.cardomain.com/ride/2297151
The higher redline of the new motor has me thinking that I may need the extra flow.
Thoughts?
Old Mar 18, 2008 | 03:25 PM
dangalla's Avatar
hmmm. now you got me thinking,
subscribe so see where this goes
Old Mar 18, 2008 | 08:27 PM
blownbird01's Avatar
I have the system. It sounds pretty awesome. I had mac mid length headers and borla exhaust before and ran an 11.49@ 121. I installed long tubes and mufflex and ran a 11.2@ 124.
Old Mar 18, 2008 | 11:16 PM
Which Mufflex 3.5".... the one with the single outlet Flowmaster or the one with the dual outlet SpinTech? They sound radically different, but appear to have similar performance capacity.
The numbers posted in the quote appear to have been derived simply by comparing the "square" of the system diameters. I saw a 4" Mufflex handle 1,125HP on a blown 383. When they pulled the Mufflex off to save weight (50#) there was no change in HP through Borla XR-1's bolted to the collectors.
Old Mar 19, 2008 | 07:21 AM
Spintech.
Old Mar 19, 2008 | 06:59 PM
Which sounds better? 4" flowmaster single out or the dual out spintech?
Old Mar 19, 2008 | 07:03 PM
dangalla's Avatar
so what do you think, am i losing alot with a single 3 inch magnaflow making ~400 rwhp
Old Mar 19, 2008 | 07:09 PM
I think I'm just going to sell it then.
I like the way mine sounds, I don't want to change it.
Old Mar 25, 2008 | 10:26 AM
mzgp5x's Avatar
I did the 3 1/2" mufflex cat_back with a spintech single pipe exit on the left side. The Spintech muffler was restriction to flow in my application (Camaro 97ss 383 - D1). I modified the Mufflex single pipe system with a qtp electric cut. That solved the problem. My application was FI, so, the mufflex "chambered" design in not a good option. Chev HiPo had a good article on exhaust systems. and, that sent me on a mission to improve. I ended up with a 3 1/2" perforated pipe dynomax glass fill straight thru 6" round muffler. Don't know how the Spintech would be on a NA application. Hope this helps. B.
Old Mar 25, 2008 | 11:24 AM
Me>you's Avatar
The Aerochamber muffler is great to about 375hp before it becomes a restriction, and 3" piping is adequate to support about that power level for a single setup...Honestly, you're in the category where it won't make a noticeable difference...The Honker sounds great, so just keep it...If you want all out performance for strip use, get yourself a cutout...
Old Mar 27, 2008 | 08:00 AM
6speedZ28's Avatar
My set up is Flow Tech LT's, ORY, and the 3.5in Mufflex/Flowmaster single out. I think it sounds great, def. noticed an increase in power over the dual-dual I had on the car before. Plus I get mistaken for a V6 "SS clone" all the time when the car is off at a show. Start it up and people are pretty suprised.
G-BODYT56
Jan 14, 2022 11:14 PM
Mar 13, 2016 03:37 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Devinfoote87
Jul 30, 2015 09:54 AM
96 TA
Sep 1, 2002 02:48 PM
