Help me choose a cam.
Old Mar 18, 2008 | 09:08 AM
jchevy's Avatar
I need help deciding on a cam.
355, srp-24cc pistons, eagle h-beams, not sure what crank yet, probably stock. I plane to run 15 psi with an intercooled t-67, log headers. I would like to make peak HP 6200 rpm max or below.
What cam should I be looking at. Would the 224-236 114 LSA be a good choice, what about the 230-236?
Right now Im using a 224-236 on a 110 LSA from when the motor was NA, should I just continue to run this one after my rebuild? WIll I notice a difference going to a 114 LSA?
Old Mar 18, 2008 | 10:15 AM
Kredz28's Avatar
Engineermike is running a 224/236 in his 388 I believe, and has said it has worked ok on his turbo setup..A 110 lsa will have too much overlap for your application. Get a cam with a wider LSA.
Old Mar 18, 2008 | 10:30 AM
jchevy's Avatar
Yeah, from searches I have seen that. I have also seen him recomend the 230/236.
Just wondering if either of these would give me what I am looking for.
MDZ28
11
Sep 24, 2015 09:15 AM
cmsmith
Jun 24, 2015 12:36 PM
CARiD
Jun 18, 2015 08:56 AM
rage366
West South Central
9
Aug 29, 2002 11:15 PM
