rough start help
Old Mar 12, 2008 | 09:55 AM
Michael982's Avatar
Question rough start help
i have a small problem with my car dunno what it is but when im at a stop it idles a little rought n then when i let of the brake and tap the gas it has a little rought take off like it kind of hesitates when i push the gas but after that it drives smooth what can it be its a 02 z28 but i just replaced the wires and plugs so i know its not that
Old Mar 12, 2008 | 10:06 AM
Michael982's Avatar
it pretty much stumbles at low or part throttle
Old Mar 12, 2008 | 11:03 AM
2000GTP's Avatar
Are there any SES codes present? Might want to check over the engine for any noticable vacuum leaks or exhaust leaks before the 02 sensors.
Old Mar 12, 2008 | 11:04 AM
ss.slp.ls1's Avatar
Is there any codes being thrown? How's your fuel pressure?
Edit: Just as 2000GTP said, I was gonna suggest to check for a vacuum leak.
Old Mar 12, 2008 | 04:11 PM
Michael982's Avatar
i think the fuel pressures low cause the fuel pump has to prime before i start it
Old Mar 12, 2008 | 06:30 PM
Green96Z's Avatar
That's normal. Check your fuel pressure first. I don't know the specs for an LS1 though.
Old Mar 20, 2008 | 01:18 PM
Michael982's Avatar
k i had it checked out at first after its been sitting if i put it in the on position it read a lil under 20psi n when i started it it read a lil under 60 the second time i tried it i let it run for a lil n it read 50 on the on position n 60 after i turned it on
i also checked the obdII n i have a bad o2 code n its been there before and after i installed the header and ory
so im thinking about gettin new o2 sensors and maf what do yall think could that be causing my stumbling
Old Mar 20, 2008 | 02:15 PM
ss.slp.ls1's Avatar
O2's have a big effect on engine function, if you have a o2 code, the corresponding o2 sensor should be fixed/replaced. I would try cleaning your MAF and looking around for vacuum leaks.
Old Mar 20, 2008 | 10:30 PM
Michael982's Avatar
thanks that actually fixed my problem i cleaned the maf n while putting it back on i noticed a hole in the vacuum line going to the front of the ls6 intake, problem solved thanks
Old Mar 21, 2008 | 12:16 AM
ss.slp.ls1's Avatar
Good to hear.
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
